Blend door actuator not working - Can I get the locations please?
130,000 MILES • 5.4L • V8 • 4WD
NASSERELSAYED
driver side blowing hot air only blend door need to be replaced but my mechanic is telling me he has to take the dash board in order to replace the acoutator please help me if you have a video for my vehicle. I already changed the one for passenger side it was behind the radio so it is only the driver side that is blowing hot air only. Thank You
Jun 14, 2016 at 2:08 PM
SATURNTECH9
  • 30,869 POSTS
Common Specs and Proc
Fluid Capacities
Tire Fitment
Reset Procedures
Service Manual
Wiring Diagrams
DTC Index
Component Locations
Technical Bulletins
Service Manual
2010
Lincoln
Navigator
5.4L Eng
FEEDBACK
Tip: LH Bend Door Actuator Replacement
Tip rating: 3. Rated by 3 shops
Posted By: tony mc
Shop: FAIRWAY AUTO CENTER
Date: 9/8/2014
a manual (single zone) system is not listed. but the LH actuator is the only actuator in a manual (single zone) system. the actuator can be reached by removing the radio. I ground down a 5/16 socket so it is real short, to loosen the rear bolt. done in less than 1 hour. no housing or dash removal! tmc
Posted By: Tech1
Shop: MARTY VANICH AUTOMOTIVE REP
Date: 9/23/2015
Nice! they do not show a single zone system. You are dead right! saved lots of headache!
Service Manual Heating, Ventilation & A/C (HVAC) Automatic HVAC System
HVAC - CLIMATE CONTROL SYSTEM
Expand
SPECIFICATIONS
DESCRIPTION AND OPERATION
REMOVAL AND INSTALLATION
Air Conditioning (A/C) Compressor
Air Conditioning (A/C) Pressure Relief Valve
Ambient Air Temperature Sensor
Blower Motor
Blower Motor Resistor
Blower Motor Speed Control
Clutch and Clutch Field Coil
Compressor to Condenser Discharge Line
Condenser Core
Evaporator Core
Floor Duct
Footwell Duct - Rear
Heater Core
Heater Core And Evaporator Core Housing
Heating Ventilation Air Conditioning (HVAC) Module
In-Vehicle Temperature Sensor - Expedition
In-Vehicle Temperature Sensor - Navigator
Mode Door Actuator - Defrost/Panel/Floor Door
Mode Door Actuator - Air Inlet Door
Plenum Chamber
Receiver Drier Cartridge
Register - Expedition
Register - Center, Navigator
Register - Driver Side, Navigator
Register - Passenger Side, Navigator
Temperature Blend Door Actuator - LH
Tip: LH bend door actuator replacement
Posted By: tony mc
Date: 9/8/2014
Comments: 1View all related comments...
Fig 1: Identifying Temperature Blend Door Actuator Components (LH)
G06133326
Courtesy of FORD MOTOR CO.
View Full-Screen
ITEM DESCRIPTION
Item Part Number Description
1 W701696 Floor duct screw (4 required)
2 18C433 Floor duct
3 W701696 LH temperature blend door actuator screw (2 required)
4 - LH temperature blend door actuator electrical connector (part of 18B518)
5 19E616 LH temperature blend door actuator
Removal and Installation
Remove the heater core and evaporator core housing. For additional information, refer to HEATER CORE AND EVAPORATOR CORE HOUSING .
Remove the 4 floor duct screws.
Remove the floor duct.
Disconnect the LH temperature blend door actuator electrical connector.
Remove the 2 LH temperature blend door actuator screws.
Remove the LH temperature blend door actuator.
To install, reverse the removal procedure.
Temperature Blend Door Actuator - RH
Fig 1: Identifying Temperature Blend Door Actuator (RH)
G06133327
View Full-Screen
ITEM DESCRIPTION
1 W701696 RH temperature blend door actuator screw (2 required)
2 - RH temperature blend door actuator electrical connector (part of 18B518)
3 19E616 RH temperature blend door actuator
Remove the Audio Control Module (ACM). For additional information, refer to INFORMATION AND ENTERTAINMENT SYSTEMS .
Disconnect the RH temperature blend door actuator electrical connector.
Remove the 2 RH temperature blend door actuator screws.
Remove the RH temperature blend door actuator.
Thermostatic Expansion Valve
Thermostatic Expansion Valve Manifold and Tube Assembly
Jun 14, 2016 at 3:25 PM
SATURNTECH9
  • 30,869 POSTS
Read the tip part not sure if that will work in your case, but it is worth a shot.
Jun 14, 2016 at 3:26 PM
MAXIMILIAM
  • 436 POSTS
Thank you so much.
NasserElsayed
Jun 14, 2016 at 5:47 PM
FREIGHT231
The one for the driver's side is buried behind the center console, under the heater box. More difficult than the upper (passenger side) but can be done w/o dash removal & draining fluids & refrigerant. About 3 hours work
Aug 17, 2019 at 9:42 PM
Thanks for the information. This original post was about 4 years ago so hopefully they have figured it out by now but this information may help others that have the same issue. Thanks for using 2CarPros. Let us know if you have any questions of your own. Thanks again.
Aug 18, 2019 at 4:58 AM
JIMMY GILLIAM
Where does the heater control valve vacuum line come from? I found a white hard vacuum line coming up from the front of the engine cross member and hooked it to the valve, but found it was plugged with screw at other end and I need to know where the blend door actuators are?
Jan 18, 2021 at 10:47 AM (Merged)
  • 55,732 POSTS
Hey JIMMY,
It should go to the internal vacuum control valve. Here is an diagram to help you find it and the locations of the blend door actuators as well . Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed.
