Blend door
50,000 MILES • 4.3L • V6 • 2WD • AUTOMATIC
1234R7X
  • 6 POSTS
The rubber on my blend door has dried and fallen off. I need to either replace the rubber or get a new door. I can't find the parts anywhere. Any help?
Jul 3, 2021 at 4:34 AM
  • 110,248 POSTS
Like you, I am having a hard time finding one. Since the manufacturer discontinued them, you may end up getting one from a salvage yard.
However, take a look at this link and let me know if that is similar to what you need. I believe that is the door even though they refer to it as a valve. The OEM part number should be 155737.
https://www.oreillyauto.com/detail/c/acdelco/acdelco-valve/acd0/155737/v/a/3381/automotive-truck-1995-chevrolet-k1500-pickup-4wd?q=blend+air+door&pos=8
Jul 3, 2021 at 2:50 PM
1234R7X
  • 6 POSTS
This is awesome. Thanks much. I have downloaded a maintenance manual for my 1995 Cheyenne but there is nothing about how to replace the door. Is that something you can help with also?
Jul 4, 2021 at 5:04 AM
  • 110,248 POSTS
I just went through two manuals, and the only thing mentioned was the actuator. I can tell you that the door is in the air distribution case. Looking at the pic, that shouldn't be too hard to access. I attached a couple of pics below.
Jul 4, 2021 at 1:52 PM
