Blend door heater blows cold air?
2008 BUICK LA CROSSE
108,000 MILES • 3.8L • 6 CYL • 2WD • AUTOMATIC
BMCMURTREY
Heater blows cold air. Both hoses are hot, so there is coolant flow.
Nov 25, 2025 at 10:28 AM
  • 55,433 POSTS
I would make sure the coolant level is full, (engine cold only). Even though you feel coolant (hot) the flow rate can be low because of a clogged heater core, you might want to remove the hoses and flush it using a garden hose. I don't think it is a blend door actuator because both sides (right and left) would need to be bad at the same time. This does have dual range climate control correct?
Here is a video to help
https://www.youtube.com/watch?v=SNRb6pSwYuU
Please upload a short video in your response of the problem, so I can see what's going on :)
Nov 26, 2025 at 2:52 AM
