Where is the blend door actuator located?
60,000 MILES • 4.6L • V8 • 2WD • AUTOMATIC
TED JENNINGS
The car listed above is a sedan. I am not getting full defrost flow at windshield. All other HVAC works great as well as the blower motor.
Jul 18, 2022 at 12:01 PM
SQM
  • 6,383 POSTS
If the issue is air flow and not the temperature, that is likely due to a faulty mode door actuator.
It is located on the HVAC box behind the dash.
I have attached the replacement procedure below for your reference.
Let me know of any questions.
https://www.2carpros.com/articles/air-vents-stay-in-the-defrost-position
Jul 18, 2022 at 2:52 PM
TED JENNINGS
Very helpful, thank you. I still can't reach it without removing the piece of ductwork or the dash piece at the steering wheel.
Jul 21, 2022 at 1:19 AM
SQM
  • 6,383 POSTS
Were you able to remove the lower trim piece below the steering wheel?
Jul 21, 2022 at 8:35 AM
