Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Chevrolet
Camaro
Climate Control
One Side
When the heat is on I get hot air on the driver's side and cold air on the passenger side
2012 CHEVROLET CAMARO
120,000 MILES • 3.5L • 6 CYL • 2WD • AUTOMATIC
PEPPERS339
MEMBER
1 POST
The same with the A/C. Do I have to remove the dash to repair it? And if so, where are the screws to remove the dash?
Nov 8, 2019 at 12:38 AM
Experienced Mechanic
Good morning,
Do you have dual controls for controlling heat and cold?
I attached the procedure and a picture for the blend door actuator but there is only one listed.
If this is the case, good chance the heater core could be clogged with debris in part of the core itself.
Images (Click to enlarge)
Nov 8, 2019 at 10:50 PM
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
