Blend door
180,000 MILES • 3.0L • 6 CYL • 2WD • AUTOMATIC
FSALTER
  • 8 POSTS
Cold air on driver side hot air on passenger side with A/C on.
Jun 9, 2019 at 10:43 PM
FSALTER
  • 8 POSTS
There are three different actuators on passenger side. how do I determine which one is not working? do I have to remove entire dash to replace it?
Jun 9, 2019 at 10:46 PM
Good morning,
I attached a picture for you to view of the actuator.
It is number 6 in the drawing.
Jun 9, 2019 at 11:14 PM
FSALTER
  • 8 POSTS
That is the one that I replaced already but I still get hot air from passenger side.
Jun 9, 2019 at 11:17 PM
When you command heat and cool, can you feel the motor move?
If you do, then it is not the actuator.
If it does not, remove the actuator and see if it moves off the case.
Jun 9, 2019 at 11:22 PM
FSALTER
  • 8 POSTS
It moves when I adjust temperature to 90 but stops when when going back down at about 78 degrees.
Jun 9, 2019 at 11:49 PM
In or out of the case?
Jun 9, 2019 at 11:53 PM
FSALTER
  • 8 POSTS
In the case.
Jun 9, 2019 at 11:55 PM
Remove the actuator and see if you can move the arm manually to get cold air.
There may be an obstruction in the case door.
Jun 10, 2019 at 12:02 AM
FSALTER
  • 8 POSTS
Okay, I will try that. but could it also be #7 in picture?
Jun 10, 2019 at 12:28 AM
If you said it moved with a command from heat to cool and back, good chance you have the correct actuator.
Check the others as well for movement.
Jun 10, 2019 at 12:30 AM
FSALTER
  • 8 POSTS
Okay, thanks.
Jun 10, 2019 at 12:31 AM
You are welcome.
always glad to help.
Keep us updated.
Jun 10, 2019 at 12:33 AM
