blend air door intermittently sticks on full heat mode?
92,000 MILES • 4WD • AUTOMATIC
GALEN MAX CLARK
If I change temperature from hot to cold back and forth several times I can get to cool. It used to make a squeaky scraping noise when I put the key to on but makes no noise when it gets stuck. I can't seem to find the location of the motor on this vehicle. Thanks, Max
Oct 20, 2022 at 6:52 AM
  • 110,248 POSTS
On this vehicle, there will be two, one for the driver and one for the passenger side. If you look at pic 1 below, it shows their locations.
The remaining pics are the directions for replacing both of them. Additionally, here is a link that explains in general how it is done. Once the actuators are located, I find it easier to follow. LOL
Take a look at the pics below and let me know if they help or if you have other questions.
Oct 20, 2022 at 1:38 PM
GALEN MAX CLARK
My Mountaineer looks like this. Thanks
Oct 27, 2022 at 4:41 AM
  • 110,248 POSTS
That looks correct. I copied your pic and circled what I believe to be the actuator.
See pic.
Oct 27, 2022 at 10:33 AM
