Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Mercury
Capri
Brakes
Bleed - Flush
Bleeding brakes
1992 MERCURY CAPRI
100,000 MILES • 1.4L • 4 CYL • 2WD • MANUAL
THOMPSONCONWAY412
MEMBER
1 POST
Bled the brakes but the proportioning valve is not working.
Feb 27, 2018 at 1:55 AM
CARADIODOC
Experienced Mechanic
What kind of symptom are you trying to solve?
Feb 27, 2018 at 3:38 AM
I assume you have a brake warning light on? Try to take like three good quick stabs at the brake pedal this should recenter the valve.
Here is a guide that can help:
https://www.2carpros.com/articles/how-to-bleed-or-flush-a-car-brake-system
Cheers, Ken
Feb 28, 2018 at 6:25 AM
Add image or video
Ask a new question
Engine has low power
Engine won't start
