Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Chevrolet
Suburban
Brakes
Bleed - Flush
brakes will not bleed
2002 CHEVROLET SUBURBAN
200,000 MILES • 6.0L • V8 • 4WD • AUTOMATIC
VACARRIER1
MEMBER
1 POST
Have replaced master cylinder and all brake lines and brakes will not bleed. What else could I check or do?
Jul 4, 2016 at 3:04 AM
SQM
Experienced Mechanic
Sometimes the brakes will not bleed if the correct procedures do not get followed.
Here is a helpful video of how to bleed ABS brake system:
https://youtu.be/nQRnKyVyMuQ
https://www.2carpros.com/articles/how-to-bleed-or-flush-a-car-brake-system
I have attached the brake bleeding procedure for both active and standard brake system below.
Images (Click to enlarge)
Oct 9, 2021 at 6:28 AM
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
