Bleeding the brakes and I am having trouble getting fluid out of the front calipers
100,000 MILES • 0.5L • V8 • 2WD • AUTOMATIC
JOHN BUONOCORE
I replaced the master cylinder, both front calipers and two lines going from master to ABS unit that has four lines coming out. I cannot get fluid out of front calipers.
Jun 14, 2022 at 7:30 AM
  • 110,251 POSTS
If you bench-bled the new master cylinder, I suspect you have air in the ABS module. However, to bleed the ABS, you need a scan tool that has the capabilities.
If you look at the attachments below, they explain the procedure. Take a look through them and let me know if you have questions.
See pic below.
Jun 14, 2022 at 2:57 PM
