bleeding air off my clutch
1996 TOYOTA
100,000 MILES • 3.0L • 4 CYL • 2WD • MANUAL
VICTORY FARM
  • 5 POSTS
Hi please help, I took the bleed screw off the clutch slave cyinder and about 200ml brake fluid came out ,the screw was blocked.how do i bleed the air out of the system now
Jan 29, 2016 at 6:25 PM
HMAC300
  • 48,601 POSTS
remove the screw and clean the screw out thee is a hole on side bottom and top, they occasionally get junk in it.
Jan 29, 2016 at 10:20 PM
VICTORY FARM
  • 5 POSTS
Many thank Boss but were do you bleed the fluid out of my toyota dyna and is there a second container to but fluid in?
Jan 30, 2016 at 12:42 AM
HMAC300
  • 48,601 POSTS
you have to bleed it like a brake system fill the master cylinder then go to the slave and open the bleed screw let it gravity drain first. never let the master cylinder empty while bleeding
Jan 30, 2016 at 1:33 AM
