Fuel line bleed port location
123,000 MILES • 3.3L • 6 CYL • 2WD • AUTOMATIC
DAN WALTON
I replaced the fuel pump and fuel filter, now engine just cranks over and does not start. I believe it is air it is air in the fuel line. Where is the bleed port for fuel?
Thanks, Dan
Aug 31, 2018 at 10:10 AM
STEVE W.
  • 15,409 POSTS
What was the reason for replacing the pump? Do you hear it prime when you first turn the key on? If you do then turn the key on and off a few times to build fuel pressure. If you do not hear the pump priming then you need to verify that it is getting power. There is no bleed port but you could check to see if you have fuel at the schrader port on the passenger side of the fuel rail.
Aug 31, 2018 at 10:29 AM
