Blazer will not start?
158,456 MILES • 4.3L • V6 • 4WD • AUTOMATIC
JODYLSCOTT61
I ran out of gas last week and when I put gas in it, it still wouldn't start. So, I replaced the starter because all it was doing was making a whining noise. And now it tries to start but it won't turn over. I put plugs wires and a starter in it. I just changed the oil and put a new oil filter in it. tries to start now but won't turn over I think it needs a distributor which I have I just haven't put in the fuel pump sounds like it's running but I don't know why it won't start. I've been told distributor, fuel pump, battery, the relay switch or that it possibly jumped timing. I don't know where to start.
Jun 27, 2025 at 5:05 AM
STEVE W.
  • 15,410 POSTS
Okay, if the starter only whines and the engine doesn't rotate you need to use a wrench and see if you can rotate it by hand. It sounds like it may be locked up for some reason. Also remove the starter to be sure it isn't binding.
Jun 27, 2025 at 11:07 AM
  • 55,710 POSTS
Yes, it is a good idea to make sure the engine rotates. I would check for spark, and then use starting fluid to see if that makes a difference. Please go over these two videos to help you:
https://www.youtube.com/watch?v=lXLJbuAZ4CE&t
Please upload a short videos in your response of any problems so we can see.
Jul 14, 2025 at 5:03 AM
