blazer won't start, need help
274,000 MILES • 4.3L • 6 CYL • 4WD • AUTOMATIC
CASSACKL
  • 10 POSTS
So last month we replaced the spider injector and the blazer ran great until this week. This week it would start but once you put it in gear it would die. Then it would have trouble starting again, it would crank crank crank like three tries and then start. Then it would go in gear and run fine. Did that for three days, then yesterday as we were driving it died. Won't start again unless you undo the fuel pump fuse and push the gas pedal to the floor, then it crank crank cranks and starts, if you plug the fuse back in and stay on the gas it stays running, but as soon as your foot comes up it dies. We were told fuel regulator (which is on the spider injector) so we replaced it. The blazer started right up and idled fine. Went 30 feet and back to square one.... Help!?
Jan 8, 2016 at 9:24 AM
CAR-MAN145
  • 321 POSTS
Sound like you may have an injector sticking open when it does not start pull the plugs to see which one is wet. Also the injectors are opened through the ground side make sure the wires going to the injectors are not grounding out somewhere
Jan 29, 2021 at 5:50 AM
CASSACKL
  • 10 POSTS
Different style of injectors then what your talking about
HMAC300
  • 48,601 POSTS
check fuel pressure with a gauge 60-66 psi auto parts rent it. must meet minimum spec key on
CASSACKL
  • 10 POSTS
We have already done that too lol.
HMAC300
  • 48,601 POSTS
so what is it? do you have spark? check fuses you may have a short in the wires recheck your work as well
CASSACKL
  • 10 POSTS
All the fuses have been checked out. It has spark. It was 62, but as soon as you shut the key off the pressure dies
CASSACKL
  • 10 POSTS
They think the ecm needs replaced
CAR-MAN145
  • 321 POSTS
you have an injector stuck open the injectors can and do stick open. That is way you fuel pressure doesn't hold when key off.
CASSACKL
  • 10 POSTS
So how do you get to the injectors on a vehicle that has a spider. Are you talking under where the connections clip in ?
CASSACKL
  • 10 POSTS
So for them to check the injectors from the ground side they will have to go deeper into the motor and the will be able to see the one stuck open then ?
HMAC300
  • 48,601 POSTS
recheck your workout probablrewed up the injection with a plug not all the way in .
CASSACKL
  • 10 POSTS
The injector was put on both times by a chevy mechanic. But we can take the plenum off and look. Right now we are trying to figure out if we need to go deeper into the motor to see if the injector is stuck open
HMAC300
  • 48,601 POSTS
it may be the pulse dampner is bad as well as a restricted fuel filter or leaking fuel line as itdoesn't hold pressure and it should.
CASSACKL
  • 10 POSTS
So the injector theory can't be because there's only one injector and it's in the spider. It could be a clog somewhere but it's flooding itself out so it's getting to much fuel
CAR-MAN145
  • 321 POSTS
There are six injectors that's what the spider legs are they don't look like regular injectors but each leg in a injector.
CASSACKL
  • 10 POSTS
Well that part gas been replaced twice in a month so I have a hard time believing it's a faulty part two times in a row.
HMAC300
  • 48,601 POSTS
i have no further comment
