black smoke and loss of accelertaion
1.6L • 4 CYL • FWD • MANUAL
M WAHAB SULTAN
  • 11 POSTS
i have replaced my car engine with a nissan qg16 but now when i press the car accelertor softly it doesnot acc but when i do it hard it creates black smoke please help
Aug 3, 2015 at 9:32 PM
KHLOW2008
  • 41,812 POSTS
Is this a carburetted or fuel injected model?
Aug 8, 2015 at 11:09 PM
M WAHAB SULTAN
  • 11 POSTS
the car is fuel injected its a nissan qg16 engine i retro fitted it in a nissan sunnny 89 model b12
Aug 9, 2015 at 12:43 AM
KHLOW2008
  • 41,812 POSTS
Are all the wiring correctly installed? Did you check for trouble codes?
Aug 10, 2015 at 12:37 AM
M WAHAB SULTAN
  • 11 POSTS
no i dont even have the grip to attach the scanner.....can u tell me reasons for this.....i think as the fuel rail is retuenless and the fuel pump keeps on pumping fuel which might be the cause....?
Aug 10, 2015 at 4:04 AM
KHLOW2008
  • 41,812 POSTS
A returnless fuel rail needs a intank fuel pump with pressure regulator otherwise the pressure would be too high at idle..
Aug 10, 2015 at 4:13 AM
M WAHAB SULTAN
  • 11 POSTS
can i install a fuel regulator on the fuel rail or do i have to mod my tank
Aug 10, 2015 at 11:20 PM
M WAHAB SULTAN
  • 11 POSTS
can i replace the fuel rail with a one with return fuel system.....like from a ga16de
Aug 10, 2015 at 11:35 PM
KHLOW2008
  • 41,812 POSTS
Yes, a fuel regulator would do but yoy must have a return line to the tank.
Aug 11, 2015 at 3:28 AM
M WAHAB SULTAN
  • 11 POSTS
Can I put Tomei fuel pressure regulator type s on the fuel rail entrance pipe and I do have a return back pipe plus I wanted to ask u where would the vacuum hose be attached to and do u have courses for people to teach them about cars.....?
Aug 11, 2015 at 3:51 AM
KHLOW2008
  • 41,812 POSTS
You can put any fuel pressure regulator as long as it can regulate correctly.
The vacuum hose can be from any part of the intake manifold after the throttle plate.
There are courses available for vehicle repairs.
Aug 11, 2015 at 4:15 AM
M WAHAB SULTAN
  • 11 POSTS
what if i dont attach a hose? and can u send me a link to the courses.... if i change my engine which should i put in a b12? sorry but can u also tell me should i dril a hole and weld a small pipe after the trottle plate to install a vacum hose
Aug 11, 2015 at 5:07 AM
KHLOW2008
  • 41,812 POSTS
Sorry but can u also tell me should I dril a hole and weld a small pipe after the trottle plate to install a vacum hose
Without a vacuum hose, the fuel pressure at idling would be too high and that would result in too rich a mixture.
Sorry I don't have any links for automotive courses but if you search around, you should be abkle to find one. It is best to get an acedemy or school near you place of residence as automotive repairs needs to be hands on and not via the web.
You already have the engine in, do you still want to change ?
For the vacuum hose, there should be available lines that you can tap from. On the manifold you should fine at least one or 2 that is suitable. If not, you can use an adapter and tap it from the PCV hose.
Aug 12, 2015 at 12:02 AM
M WAHAB SULTAN
  • 11 POSTS
can u tell me whcih port will share the vacuum port with the pressure regulator.....
Aug 12, 2015 at 5:53 AM
KHLOW2008
  • 41,812 POSTS
Sorry the picture is not showing. Any port that has vacuum when engine is idling would do.
Aug 13, 2015 at 1:41 AM
M WAHAB SULTAN
  • 11 POSTS
sir do u have an email the pictures are not being uploaded here
Aug 13, 2015 at 2:46 AM
KHLOW2008
  • 41,812 POSTS
The picture is not going to be relevant as I might not be able to know which has vacuum. You only need to find out which port has vacuum when engine is idling.
Aug 14, 2015 at 12:06 AM
M WAHAB SULTAN
  • 11 POSTS
how can i do that?
Aug 14, 2015 at 10:01 PM
KHLOW2008
  • 41,812 POSTS
Start the engine and test the port for vacuum.
Aug 15, 2015 at 1:40 AM
M WAHAB SULTAN
  • 11 POSTS
what would the vacum port do
Aug 20, 2015 at 11:38 PM
KHLOW2008
  • 41,812 POSTS
When the engine is running, the vacuum port would have suction.
Aug 29, 2015 at 11:27 PM
