when accelerating in first gear a little cloud of black smoke?
90,000 MILES • 1.4L • 2WD • MANUAL
CHAPPSY
Hi, I’ve had the car a week bought from a dealer, it’s a 14L Kia Venga crdi turbo
Economic, 2011 year with 90,000 miles on the clock, it’s got a full-service history and was last serviced 2 weeks ago. I’ve just noticed when accelerating in first a little cloud of black smoke, it doesn’t do it in any other gears, just in first, does anyone know what this could be? I'm thinking of returning the car for a refund or if it’s an easy fix will stick with it?
Oct 24, 2022 at 8:15 PM
  • 55,721 POSTS
Diesel engines do let out little buffs of black smoke, which is normal. do you have a check engine light on? This would indicate there is a problem. Here is a guide for gasoline engines that have black smoke which some problems do cross over:
https://www.2carpros.com/articles/engine-black-smoke
Has the fuel filters been changed? I would try that first if no check engine light is on.
Oct 25, 2022 at 4:14 AM
CHAPPSY
Hi Ken L,
Thank you for your reply, there’s no warning lights on, not sure if they changed the fuel filters when they did a service. I will call them and check. Do you think adding additives to the fuel could help?
Oct 25, 2022 at 5:27 AM
  • 55,721 POSTS
Yes, I would try the fuel additive to help clear out any bad fuel. Let me know if the filters were done, that is a big problem on diesel engines.
Oct 26, 2022 at 3:15 AM
CHAPPSY
Hi, the filters have been done, no warning lights on, so I'm going to try the addictive's and I hope this helps. Maybe it’s normal having the little blasts of smoke. Thanks for your advice.
Oct 27, 2022 at 9:21 PM
  • 55,721 POSTS
Please let me know if the problem improves. Use 2CarPros anytime, we are here to help. Please tell a friend.
Oct 29, 2022 at 7:29 AM
