Surging issue?
175,000 MILES • 1.7L • 4 CYL • 2WD • MANUAL
GARRICK93
I have a surging problem, I've burped the system for air and checked for vacuum leaks, changed the IAC and the connector. Checked all wiring to the connector and all have power expect the black/red wire. (Even tried and different connector same issue. I've tried looking up the wiring diagram to see what the wire is used for but i can't get any results on my d17a2 engine. Would definitely would like some help figuring out the cause of my surging as well.
Mar 10, 2025 at 2:36 AM
  • 55,694 POSTS
Do you have a check engine light on? Let's run the codes to see if any are stored.
Here is a guide that goes over popular reasons for an engine to surge, which can be ignition timing, a bad distributor, or an engine vacuum leak.
https://www.2carpros.com/articles/engine-surges
Are the spark plugs new and gapped correctly? Please go over these guides and get back to us.
Mar 11, 2025 at 5:58 AM
