Black coolant in the plastic jug?
230,000 MILES • AUTOMATIC
BABA YAGA
Have black coolant in the plastic jug under hood, I believe it’s the reserve tank and the fluid smells like oil.
Jan 30, 2025 at 10:39 AM
  • 55,711 POSTS
Yep, this happens when the transmission oil cooler goes bad, here is the location so you can swap it out, you will need to flush the cooling system using a chemical flush you can get from the auto parts store. Check to see if the transmission fluid is dark as well to help confirm the issue. Also, this guide can help:
https://www.2carpros.com/articles/transmission-fluid-in-radiator-coolant-reservoir
You will need to replace the radiator if the fluid color is confirmed. Please upload pictures or videos in your response of any problems so we can see what to help you with.
Feb 1, 2025 at 3:12 AM
FARR2007
  • 244 POSTS
Are you positive it’s the transmission oil cooler hose? Also, where is that located?
Feb 1, 2025 at 8:10 AM
  • 55,711 POSTS
The cooler is inside the radiator, please go over the guide above. It could be a blown head gasket as well, since there is oil pressure going through the head gasket. I need you to see what color the transmission fluid is. If it is red and normal, my guess is that the head gasket is bad.
Feb 2, 2025 at 12:54 AM
