Black box with two hoses, what is it
145,000 MILES • 4 CYL • TURBO • 2WD • AUTOMATIC
MOTORIDER323
I am a diesel mechanic and I work on a fleet of Isuzu’s, although becoming very familiar with this fleet and the trucks themselves sometimes I scratch my head at things. There is a black box that has two 1” hoses coming out of it, one hose runs to the cylinder head, the other to the bottom of the truck as a what I believe is some sort of overflow relief. This box is located behind the throttle linkage on the left side and directly under the fuel filter and its housing. I could not find anything about this box or what it does. Best I could come up with was some sort of overflow relief. One of the mechanics put way to much oil in the pan when doing a oil change and there was oil coming out of this tube that leads to that box which in return has the other hose that leads to the head. Anyone know what this is?
Nov 24, 2018 at 2:42 PM
  • 110,251 POSTS
That is an interesting one. Can you upload a picture of it? Also, based on your description, it almost sounds like a crankcase ventilation unit. Being that is located on top, I do not think it would be an overflow.
Take a look at the picture I found online. Tell me if that looks like the part. If it does, it is for crankcase ventilation.
Nov 25, 2018 at 10:54 AM
MOTORIDER323
Yeah looks similar but not exactly but having another opinion has made me confident that is what that is. Even being ASE certified and working on these trucks everyday sometimes I stumble across things I need a second opinion on. Thanks for the response.
Nov 25, 2018 at 12:27 PM
  • 110,251 POSTS
Happy to help. And you are not alone. I have the same issues all the time.
Nov 25, 2018 at 2:23 PM
