Big parasitic drain
40 MILES • 4.1L • V8
PETER BAGDON
The red and orange wires coming from the positive terminal junction under the hood are using 12v. Ignition switch is not shorted. Removing fuses or ECM does nothing. When i remove the connector at the firewall drivers side it stops. Or if I remove the blue connector on the ignition switch it stops.
Apr 14, 2021 at 12:51 AM
Good morning,
I attached a guide for you to follow. Check the procedure and let me know which fuse stops the draw.
https://www.2carpros.com/articles/car-battery-dead-overnight
You are allowed 50 to 75 milliamps draw.
Apr 14, 2021 at 1:55 AM
