Best shock absorb-er
122,000 MILES • 3.3L • V6 • AWD • AUTOMATIC
UJBAFS
I want to replace the rear shock because the one the mechanic changed was making noise so I do not want to fall into trouble. So I want the one that suits my car with good quality. I do not know between Monroe, KYB or OXC which has best quality for my car.
Also, it has VSC light on which the code P0420 catalyst system efficiency below threshold (bank1); code P0430 (bank2).
Please help me with the best parts of the vehicle if possible email me the pictures.
Thanks a lot
May 28, 2017 at 1:30 AM
HMAC300
  • 48,601 POSTS
go to rock auto.com for pictures of parts and put your car information in. as far as VSC a mechanic will need to scan for codes to see if it is an ABS or VSC problem to fix that. the converter codes mean your converters are bad and need to be replaced you can find them at rock auto as well with prices.
May 28, 2017 at 11:25 PM
