Best fuel pump for replacement
120,000 MILES • 4.6L • V8 • 2WD • AUTOMATIC
THEPRINCEXIV
Hey, I have to replace my fuel pump on my car and I'm shopping around for a decent fuel pump and I'm just not sure which company to go with. Any advice on a reliable yet wallet friendly fuel pump? thanks!
Dec 13, 2020 at 9:56 AM
  • 110,248 POSTS
You are always best to go with an OEM pump. If you can't, there are several that are good. Bosh makes a good one, Airtex does, Denso, AC Delco and so on are all good.
________________________
Here are directions for pump replacement. The attached pics correlate with the directions.
2003 Ford Mustang V8-4.6L DOHC VIN R
Procedures
Vehicle Powertrain Management Fuel Delivery and Air Induction Fuel Tank Unit Service and Repair Procedures
PROCEDURES
REMOVAL
1. Remove the fuel tank.
pic 1
2. Remove the module assembly flange bolts.
NOTE: For installation, tighten the bolts in the sequence shown.
3. Clean the area around the fuel delivery module mounting flange.
pic 2
4. Lift the fuel pump, carefully detach the fuel float arm and remove the fuel pump from the fuel tank.
INSTALLATION
1. To install, reverse the removal procedure.
NOTE: Install a new fuel pump O-ring.
You will need to remove the fuel tank to access the pump. Here are the directions for that. The remaining pics correlate with the directions.
Fuel Tank Removal and Installation
Vehicle Powertrain Management Fuel Delivery and Air Induction Fuel Tank Service and Repair Procedures Fuel Tank Removal and Installation
Fuel tank removal and installation
Removal
Warning:
^ Do not smoke, carry lighted tobacco or an open flame of any type when working on or near any fuel-related components. Highly flammable mixtures are always present and may be ignited, possibly resulting in personal injury.
^ Fuel supply lines on all vehicles equipped with fuel injected engines will remain pressurized for long periods of time after engine shutdown. Fuel system pressure must be relieved prior to fuel system service to prevent possible personal injury or a fire hazard.
1. Disconnect the battery.
2. Relieve the fuel system pressure.
3. Drain the fuel tank.
4. Raise the vehicle.
pic 4
5. Remove the filler pipe bolt and disconnect the filler pipe hose connections to the fuel tank.
pic 5
6. Disconnect the fuel tank electrical connector.
pic 6
7. Disconnect the vapor tube fitting at the left front of the fuel tank.
pic 7
8. Disconnect the EVAP canister tube and hose.
pic 8
9. Place a safety support under the fuel tank.
pic 9
10. Remove the front bolts from the fuel tank support straps and swing the LH strap out of the way.
pic 10
11. Remove the RH fuel tank support strap bolt and remove the strap.
12. Partially lower the fuel tank and disconnect the fuel line.
pic 11
13. Cut outer edge of pipe-to-tank grommet to facilitate pipe removal and carefully remove the grommet from the fuel tank. Take care to avoid damage to the filler pipe check valve.
CAUTION: The filler pipe grommet must be removed prior to removing the fuel tank from the filler pipe or damage to the fill tube check valve will occur.
14. Lower the fuel tank from the vehicle.
INSTALLATION
pic 12
pic 13
pic 14
CAUTION: Lubricate the filler pipe check valve area and the tank-to-filler pipe grommet with Surfactant prior to assembly or damage to the filler pipe check valve will occur.
NOTE: A new grommet must be used for the installation procedure due to its destruction during removal.
__________________
I hope this helps. Let me know if you have other questions.
Dec 13, 2020 at 2:07 PM
