Best bidirectional scanner for ford products?
64,000 MILES • AUTOMATIC
STRICTLYDIMES
  • 29 POSTS
I am considering purchasing a bidirectional scanner. I work on 2003–2011 Ford Panther-platform vehicles, including Crown Victoria, Mercury Grand Marquis and Lincoln Town Car.
What scanner can communicate with the following modules on these cars: PCM, ABS, RCM/SRS, LCM, EATC/HVAC, PATS, DDM and RASM.
Right now I’m needing to look into a 2005 Mercury Grand Marquis, 2006 grand Marquis and a 2004 Lincoln town car with factory rear air suspension.
I need a scanner to perform the RASM self-test and active/bi-directional tests, commanding the compressor, vent solenoid and individual rear air-spring solenoids? Also read the rear height sensor live data and perform the ride-height calibration procedure?
I’m not sure if all bidirectional ones provide the exact vehicle year/model/module/function coverage some just say that the scanner has ‘full-system’ or ‘bi-directional’ capability. I’ve tried contacting manufacturers but either havent got a definitive answer or any answer at all. My budget in under $500. Thanks for your input.
Sep 3, 2026 at 10:47 AM
CARADIODOC
  • 34,413 POSTS
You're going to have to look for an out-of-date used scanner if you need to stay under $500.00. By "out-of-date", you could translate that into, "good value".
My first scanner was a Monitor 4000, made by the same company that made the DRB2 for Chrysler. The Monitor will do Chrysler, GM, and Ford with one cartridge, but only up to 1995 models.
Next, I got two DRB2s, (diagnostic readout box, version 2), then a new DRB3, but those are specific to Chrysler. The DRB3 is capable, with an extra, plug-in card, of working on any brand of vehicle sold in the U.S. starting with '96 models, but only emissions-related stuff. Because of that, a lot of independent shops bought them. It went obsolete on various models between 2004 and 2008. Those would not access the computers you mentioned on other brands, but these can still be found as shops sell theirs to buy something newer.
My next scanner was a Snapon Solus Edge. A friend has one for his shop, but he keeps his updated. That costs him over $1000.00 per year. For your needs, I'd recommend you do what I did. Mine came from a reseller on eBay. I bought it in 2018, updated to current at that time, and I never updated it further after that. My two newest vehicles are 2014 models, and I plan to never own anything newer, so this is all the scanner I need. Since the annual updates are so expensive, a lot of shops have one that they keep updated, and one or two others that they allow to become outdated, then they only use those on the older cars. To update a Snapon scanner, you can't skip any years. For example, I would have to buy the 2019 update before I could buy the 2020 update, then I could get the 2021 update, etc. After five or six years, the updates would cost more than a brand new scanner. That's what can work to your advantage. Shops find it less expensive to buy a new scanner, then they can sell the old one and let someone else update it or use it as is, like I'm doing. A few years ago, there were a couple of dozen of these on eBay, updated through 2014 to around 2016, for as little as $750.00. All you have to do is pick one updated through at least 2005 for your Ford.
Based on a glowing recommendation from one of our other experts, I bought my last scanner two years ago and it's a much better value than anything Snapon has. It's made by Autel. It does more than my Solus Edge, including the ability to program modules and key fobs, and cost just a little over $1300.00. With a new Snapon scanner, you have to pay extra for Asian import coverage, and more again for European import coverage. The Autel covers every car brand in the world, if you care to download all of them, like I did. That's right. I can work on a Russian car if it shows up. So far, I used it to program three modules in my friend's shop. He would have spent almost that much if he had to haul those cars to the dealers to have that done.
You can get some pretty nice fault code readers that will also display live data, and many of the better ones can access ABS and Air Bag /computers now, but they're only good for basic information. If you're going to use one on a regular basis, you're going to be quite unhappy with how slowly the screens update. Two or three seconds might not sound bad, but it can be painfully slow when you need data now, and it's impossible to catch momentary glitches in sensor signals. These readers cost less than $100.00. If you need one often enough that you took the time to ask, you'd be better off spending the extra dollars for a full scanner.
The displayed data on scanners updates about a half dozen times per second. You still can have glitches go by much too fast to see, so almost all scanners also have a "record" feature that lets you record a few seconds of data that can be played back slowly, later, to watch for those glitches. In the case of the DRB3, you can take it along on a test drive, then you press the "record" button when the hiccup occurs. Because all the data travels through the scanner's memory, the recording actually begins a couple of seconds before you pressed the button. That prevents getting there too late after the event has occurred.
The Solus Edge can graph and record at least four things at the same time, and for a pretty long time. I think it can record for more than a couple of minutes. It comes with the standard cable to plug into the data port under the steering column on 1996 and newer models. For '95 and older models, every manufacturer had their own proprietary computer language and diagnostic plugs, so you will need a different cable, and then the appropriate adapters for the cars you want to work on. I bought about two dozen different adapters, including a kit covering all of the European brands, on eBay. A lot of them cost less than ten to twenty dollars.
There are a lot of other good scanners out there, but these that I listed are the ones I own for my own use and am very familiar with. Some of our other experts may stop in to offer their suggestions.
Sep 3, 2026 at 6:38 PM
STEVE W.
  • 15,403 POSTS
Being you are looking for Ford only you might want to look at the full windows version of FORScan. https://forscan.org/home.html It is pretty much a clone of the factory software for Ford and some Mazda vehicles. You can download the free version and see what you think. You will want the specific dongle they use but read up on it and see what you think. I've used it a lot over the years even though I have a bunch of other scan tools. It has a few features for the Fords that others omit.
Now if you work on other vehicles as well, you might want to look at Autel and Topdon machines. Both are very good.
Sep 4, 2026 at 2:06 AM
STRICTLYDIMES
  • 29 POSTS
Thanks everybody for those detailed replies. I’m going to check out the manufacturers you mentioned and see if they are pertinent for me
Sep 6, 2026 at 5:52 PM
STRICTLYDIMES
  • 29 POSTS
Does anyone know if the v-Linker MC+ (BLE+BLUETOOTH) is what I would need ? (I have an iPhone)
thank you
Sep 7, 2026 at 10:10 PM
STEVE W.
  • 15,403 POSTS
I looked at that products website. That isn't a scan tool it is only an interface device that would transmit data to the phone from the vehicle. You then need software on the phone to use the device. However, the apps it lists are also limited in that they are not bidirectional. You can read some codes and erase them but any testing beyond that isn't possible. I read that it will work with FORScan on windows but not on the Iphone.
Sep 8, 2026 at 4:39 AM
