Bent lower control arm
210,000 MILES
MONEYSAM83
  • 32 POSTS
Here is the background i went to customers house to change the driver side lower control arm which obviously was bent at the bottom due to impact with the curb, i checked the sub-frame all the welds are in tact, no visual bends, but what noticed after i changed the lower control arm the drive knuckle also has a huge crack so i told them they have to change that, now the main question i have is am i going to have to change the strut too? The wheel is still slanted due to impact on the driver side the lower control arm is new. The wheel is poked out at the top a lot.
Jun 28, 2016 at 7:48 AM
HMAC300
  • 48,601 POSTS
if you changed the knuckle and did not get it aligned may be the reason it is out at the top. You cannot really eyeball the alignment.
Jun 28, 2016 at 8:35 AM
CARADIODOC
  • 34,413 POSTS
The first thing I would look at is the two lower mounting holes on the strut body. They are perfectly round from the factory, but aftermarket struts come with an elongated lower hole to make them adjustable. Even if these are original, the lower hole can be ground to an oval shape when camber needs to be adjusted. If that lower hole is slotted, the adjustment could have slipped from the impact.
If the strut is bent, they usually make the wheel tip in on top. That is from a crash with another car. When the bottom of the wheel hits a curb, there is usually too little leverage to bend the strut. The lower control arm, then the wheel are more likely to be what gets bent. Look at the space between the top of the tire's sidewall and the strut body, and compare that on both sides. If the gap is bigger on the left side, then the strut may indeed be bent.
I am not sure what you mean by "drive knuckle". Are you referring to the outer cv joint?
Jun 28, 2016 at 8:44 AM
MONEYSAM83
  • 32 POSTS
I have not got the knuckle yet, but a friend of mine told me i was going to have to change the strut too. is that true?
MONEYSAM83
  • 32 POSTS
The drive spindle the part that holds the axle that is what i meant by drive knuckle.
Jun 28, 2016 at 8:55 AM
MONEYSAM83
  • 32 POSTS
I am going show you a picture @cardiodoc.
Jun 28, 2016 at 12:45 PM
MONEYSAM83
  • 32 POSTS
This is with the wheel straight.
Jun 29, 2016 at 2:29 AM
HMAC300
  • 48,601 POSTS
check your tie rod ends inner and outer they are either way out of adjustment on one side or bent badly. do not drive this car like that it will shred the tire in no time flat. have a professional look at it to see what is really bent you may have wasted your money on the control arm.
Jun 29, 2016 at 3:17 AM
CARADIODOC
  • 34,413 POSTS
Yup. Your last sentence in your original post said, "The wheel is poked out at the top a lot." This is turned to the left and that is not a strut or control arm issue. If that was the case, you solved that already. This is something different, and as brother HMAC300 said, it is a tie rod issue. The wheel is turned too much for this to simply be out-of-adjustment. There is not that much adjustment in the threads. The tie rods on this car are behind the wheels, so one that is bent will cause that wheel to turn away from the center of the car, like this one is. You wont bend the outer tie rod end. It is too short. The inner one is real long and it is the weakest part in the system.
Jun 29, 2016 at 4:39 PM
MONEYSAM83
  • 32 POSTS
I changed the spindle/drive knuckle that solved the problem
Jul 19, 2016 at 7:03 AM
CARADIODOC
  • 34,413 POSTS
Dandy. Happy to hear it's solved. Come back and see us again.
Jul 19, 2016 at 10:39 AM
MONEYSAM83
  • 32 POSTS
Ok
Aug 3, 2016 at 1:59 PM
