Serpentine/AC belt replacement
129 MILES • 4 CYL • AUTOMATIC
VERONICA GARCIA2
How to replace A/C and serpentine belt?
May 3, 2020 at 1:05 PM
  • 55,694 POSTS
Here is a guide to help you step by step with the diagrams in the link below:
https://www.2carpros.com/articles/replace-serpentine-belt
and
https://www.2carpros.com/diagrams/chrysler/lebaron/1992
May 4, 2020 at 5:18 AM
I included the process for each belt. The accessory drive belt has a tensioner and then the A/C belt has an adjusting screw.
Let me know if you have questions and we can go from there. Thanks
May 4, 2020 at 5:27 AM
VERONICA GARCIA2
Thank you. both belts replaced and now there's a high pitch squealing, squeaked before just not as bad. Replace pulleys?
May 12, 2020 at 11:43 AM
Yes. This is most likely a pulley. Now that the belt is new and tighter then the old belt it is putting more pressure on the pulley and it is making more noise.
The way to find out which one this is so you don't have to replace them as guesses. You can get a mechanic stethoscope and it will pinpoint which bearing it is. They are about $5.00 from most online stores.
https://www.2carpros.com/articles/car-squeaking-noise
May 12, 2020 at 11:48 AM
