Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Toyota
Avalon
Engine
Serpentine Belt
Diagram
Serpentine belts
2003 TOYOTA AVALON
130,000 MILES • 3.0L • V6 • 2WD • AUTOMATIC
PAWNGUY
MEMBER
all i see are routing guides for serpentine belts, my car has 2 regular belts. is that common?
Sep 18, 2021 at 6:42 PM
Experienced Mechanic
Good morning,
The power steering has only one belt from the crank pulley inner mounting to the pump.
The alternator and the A/C compressor are run by the other belt. I attached some pictures for you of the routing.
https://www.2carpros.com/articles/replace-serpentine-belt
Images (Click to enlarge)
Sep 18, 2021 at 9:29 PM
PAWNGUY
MEMBER
Thank you. I didn't understand that it was still called a serpentine belt being so short.
Sep 20, 2021 at 1:46 PM
No problem.
The new belts use both sides of the belt. That classifies it as a serpentine belt.
The old belts were V belts that sat in a groove. The serpentines are flat.
Sep 20, 2021 at 6:33 PM
Add image or video
Ask a new question
Engine won't start
Check engine light
