I just replaced the belt tension-er and drive belt. Is it normal to do this? Or should be quiet and with not any play being able to move? I checked the belt tension-er to see if it was loose and it was tight even tho it rattles back and forth when engine running. Everyone told said it is normal because the tension-er needs to have some play so the belt and accessories can move smoothly. But does rattling mean the tension-er has an issue?
Oct 21, 2018 at 2:35 PM
