Belt tensioner will not rotate to release tension to remove belt
138,000 MILES • 2.2L • 4 CYL • 2WD • AUTOMATIC
WRENCHERHEAD
  • 34 POSTS
I'm using proper tool for it and all that's happening is that the pulley and the 15mm bolt will turn in its stationary position but will not move tensioner to unload tension from belt (as if belt was too loose or bolt was loose). yet the belt has full tension and there are no symptoms of any type of noise/squeal. The belt is new and no sign of abnormal wear or cracking. It feels like the bolt is coming loose or stripped but again the bolt is secure. Is it possible that spring is broken or worn out and still retain tension on the belt? This is left me at a standstill. Please reply ASAP. Thanks, Mark
Jun 6, 2019 at 5:31 AM
DANNY L
  • 5,648 POSTS
Hello, I'm Danny.
Yes, it's possible something has frozen up internally in the tensioner. Here is a tutorial showing how to replace:
https://www.2carpros.com/articles/serpentine-belt-tensioner-replacement
Sounds like you know what to do already but I've attached that and a picture below for reference.Hope this helps and thanks for using 2CarPros.
Danny-
Jun 6, 2019 at 7:33 AM
WRENCHERHEAD
  • 34 POSTS
Hi Danny, my apologies for taking a week to respond back to you, but I have little to no time for myself since I've been taking care of my parents who are 90 and 94 years old 24/7 going on six years now plus trying to squeeze in time to fix my car. It's been overwhelming to say the least. At this moment they're both napping, so I'm using this opportunity to reply. I wanted to thank you for responding so quickly to my question about the tensioner. I was about 98% sure the tensioner was shot, but wanted to verify it from a professional tech. Also, thanks for the information and pictures. I've been wrenching for 53 years and worked for GM dealers for 26 years in parts department. but this is the first tensioner I've come across that retained its load when going bad, I do have another question for you though about my surge tank. My OEM tank was a first design tank with only one vent line. It's n/a anymore from GM or aftermarket. I had to get the second design tank which has two vent tubes, so I capped off the second tube with rubber vac caps. Since they're somewhat soft I used two caps,1 that fit the tube dia and 1 that fit over the first cap
and hose clamped but I'm concerned that they will not hold the pressure or will fail from the heat and coolant. It's 15psi. Would plastic welding the end of tube closed be sufficient? thanks, wrencherhead (Mark) 1996 Cavalier 2.2L TH125C
Jun 13, 2019 at 9:28 AM
WRENCHERHEAD
  • 34 POSTS
Hi Danny, don't know if you got my reply from last night so I'm writing it again. First off my apologies for taking a week to reply but I'm a 24/7 caretaker of my parents who are 90 & 94 so time for myself is little to none. Thanks for your quick response about my tensioner. I was about 98% sure the tensioner was shot. Although I'm not ASE certified I 've been wrenching for about 53 yrs 26 with GM dealerships in parts so I'm quite knowledgeable & experienced to include my own ground-up restoration on my 69 Camaro to building my own rotisserie. Anyhow I have another question, the OEM surge tank with 1 vent tube is N/A anymore, only the tank with 2 vent tubes, so temporarily I capped off 2nd tube with vac caps. Since they're soft rubber I placed t to fit tube dia & a 2nd one to fit over 1st cap & hose clamped but I'm not confident that it won't fail due to 15psi, heat & coolant. Would plastic welding the tube end be sufficient or do you have a better suggestion? Thanks wrencherhead. 96 cavalier 2.2L TH125C
Jun 14, 2019 at 1:44 AM
DANNY L
  • 5,648 POSTS
Hello again.
Yes, I wouldn't use vacuum caps.. Due to its under car location/exhaust heat I wouldn't trust those. They do make a plastic weld but I can't remember the name. I would look for some type of plastic cap and epoxy it on.. Hope this helps and thanks again for using 2CarPros.
Danny-
Jun 16, 2019 at 8:46 AM
WRENCHERHEAD
  • 34 POSTS
Hey Danny. Just noticed there was a second answer from you on my surge tank. I'm going to plastic weld tube end. I'll feel more confident it will be a permanent fix. Thanks for advice.
wrencherhead
Jun 17, 2019 at 3:50 PM
DANNY L
  • 5,648 POSTS
You're welcome! Thanks for using 2CarPros.
Danny-
Jun 19, 2019 at 7:31 AM
