Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Oldsmobile
Aurora
Engine
Serpentine Belt
Replace/Remove
belt replacement
1998 OLDSMOBILE AURORA
140,309 MILES • 4.0L • V8 • FWD • AUTOMATIC
JOHN GRIGSBY
MEMBER
1 POST
how do I route the serpentine belt?
Jun 6, 2017 at 1:51 PM
STEVE W.
Experienced Mechanic
Should go like this. You will need to jack up the front, remove the right side front tire and remove the splash shield to get to the crank and AC pulleys to get the belt on. If the tension-er has not been replaced now would be a good time.
Image (Click to enlarge)
Jun 6, 2017 at 2:44 PM
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
