Belt drive installation
287,453 MILES • 0.5L • 6 CYL • 2WD • AUTOMATIC
KYAZZIE19
Diagram, what could cause to come off. Can I just put it right back on?
Mar 29, 2020 at 9:00 AM
DANNY L
  • 5,648 POSTS
Hello, I'm Danny.
It's possible the belt tensioner is weak/not holding tension any longer.Here is a tutorial showing what is involved for its replacement and replacing the belt:
https://www.2carpros.com/articles/replace-serpentine-belt
https://www.2carpros.com/articles/how-a-serpentine-belt-tensioner-works
https://www.2carpros.com/articles/serpentine-belt-tensioner-replacement
I've attached a diagram below as you requested on the proper belt routing.Hope this helps and thanks for using 2CarPros.
Mar 29, 2020 at 10:00 AM
