Shut off while driving, now will not stay running
215,000 MILES • 3.8L • 6 CYL • 4WD • AUTOMATIC
R.VARGAS
Wife was driving said she heard some kind of noise then upon stopping engine stalled and would not start. I got it to start but it wants to shut off immediately unless I feather the gas. Did this for ten minutes and still when let off accelerator it shut off. Help
Feb 15, 2019 at 4:59 PM
  • 110,248 POSTS
If the check engine light is staying on when the engine is running, you need to have the computer scanned to identify diagnostic trouble codes. Here is a quick video that shows how it is done:
https://youtu.be/YV3TRZwer8k
I realize most people don't own a scanner, but most parts stores will scan it for free or rent a scanner to you. Once you have that done, let me know the codes that were found.
Next, here is a link that discusses the most common causes for an engine not to idle (stall at idle). Take a look through it.
https://www.2carpros.com/articles/stall-at-idle
Let me know if anything in that link is helpful. Also, engine idle speed is controlled by a component called an idle air control valve (IAC). If the IAC is plugged or not working, the engine will not idle. Here is a link that discusses how one is replaced. You may want to remove yours and inspect it for carbon or dirt contamination.
https://www.2carpros.com/articles/how-to-replace-an-idle-speed-control-motor-iac
Additionally, check to make sure there are no engine vacuum leaks. Confirm that the air inlet tube between the air filter and throttle body is properly attached. Here is a link that shows how to check for engine vacuum leaks:
One last thing. Can she describe the sound she heard?
Feb 16, 2019 at 3:27 PM
R.VARGAS
She cannot, part of the issue. I've got p2030, p2430, p0056. Traced all of the spaghetti factory, wires vacuum lines. No damages. Also O² came up as INC. incomplete, or inconclusive?
Feb 18, 2019 at 3:17 AM
  • 110,248 POSTS
Welcome back:
None of those would cause it not to stay rinning. The P0056 is related to the heated o2 sensor, but again, that wouldn't cause it not to start.
The inconclusive you are getting is most likely because someone cleared the codes and the computer hasn't completed the number of drive cycles required to identify everything is working. Most likely, you are checking the emissions readyness on the scanner.
Next, have you checked fuel pressure?
Let me know,
Feb 18, 2019 at 9:13 AM
