Shut off while driving and will not start
125,000 MILES • 1.8L • 4 CYL • 2WD • MANUAL
DAVID GASPER
The starter spins but does not turn motor. Checked codes showed crank shaft position sensor two knock sensors and misfire on cylinders 1, 3 and 4. Replaced crankshaft position sensor still no change.
Aug 23, 2018 at 8:26 PM
  • 55,721 POSTS
Can I ask if you can see the engine cranking over or is the starter spinning and the engine just sits there? Please let me know.
Aug 25, 2018 at 7:20 AM
DAVID GASPER
Yes, the motor turns and has a backfire every once in a while.
Aug 26, 2018 at 5:22 AM
  • 55,721 POSTS
Okay, lets start by doing a compression test to help us see if you have a mechanical problem or not, or you can make a quick video of the engine cranking over which I can tell from that you can upload it in your response. Here is a guide to help with the compression test:
This link can help as well:
Cheers, Ken
Aug 27, 2018 at 2:53 AM
DAVID GASPER
Thank you. I will check on all that this evening and get back to you.
Aug 27, 2018 at 2:55 AM
