Beeping when turning off engine?
1992 HONDA ACCORD
109,000 MILES • 6 CYL • 2WD • AUTOMATIC
MARCIA ROVINS
Twice, in the past few weeks, when I shut off my engine and take the key out the car beeps like it would had I left the headlights on. If I take it out of park and put it back again, it's fine. It's really hot here in S. Nevada and I believe both times it happened I had driven home after my car was out in the sun for a few hours.
Aug 10, 2025 at 9:10 AM
  • 55,433 POSTS
To me it sounds like the ignition switch is worn out, this will cause the beeping like you left the key in the switch. If it only does it in the hot weather I would not worry about it. The only thing I would look at is to make sure the car is not overheating which may cause the chime as well.
Aug 11, 2025 at 3:57 AM
MARCIA ROVINS
Thanks so much for the reply.
Aug 11, 2025 at 5:10 AM
  • 55,433 POSTS
You are welcome, let me know if you need anything else, we are here to help.
Aug 11, 2025 at 6:14 AM
