Beeping noise
61,000 MILES • AUTOMATIC
GAIL WATSON
The car started beeping under the glove compartment when I take the key out of ignition.
Jun 5, 2018 at 1:05 AM
  • 110,248 POSTS
Hi Gail and thanks for using 2CarPros.com. Behind the glove box there are relays, but I never heard of them beeping. Does the noise eventually stop? Is it a steady beep? How loud?
Jun 7, 2018 at 12:16 PM
GAIL WATSON
It is not a steady beep. Only happens when I remove the key from the ignition. It is loud enough to still hear it when I have left the car and shut the door. It stops a few seconds later.
Jun 9, 2018 at 5:59 AM
  • 55,746 POSTS
Does it sounds like a door chime? Can you do a short video of the problem and upload it here in your response?
Jun 12, 2018 at 3:54 AM
