Okay. So it doesn't happen every time you drive? If it only happened once, then it may have just been a stuck door switch. IF it happens again, just look and see if there are any warning lights on in the dash. More than likely you will have a light if it is something like this. However, if it is not doing it now, then it will be next to impossible to figure it out because we need it to act up to start eliminating things.
Oct 14, 2019 at 10:18 AM
