Front wheel bearings replacement
83,000 MILES • 4 CYL • 2WD • AUTOMATIC
RIFFIE C HOLT
How do I replace the front wheel bearings? I have brake caliper off but trying to loosen lug bolt and the rotor and everything is turning.
Sep 16, 2018 at 9:56 AM
PATENTED_REPAIR_PRO
  • 1,853 POSTS
Put the caliper back on and pump up the brake, then have someone else hold down the brake pedal, or place a stick in between the brake pedal and seat cushion, then loosen the lock nut.
Sep 16, 2018 at 11:28 AM
