Possible bearing out of round
180,000 MILES • 3.0L • V6 • 4WD • AUTOMATIC
CCURRELL
Trying to replace rear bearings. Did the drivers side and it looks like everything went well. The passenger side is a different story. The bearing on this side was very bad and driven months with a hollowing bearing. I have installed three bearings on this side in two days and the hub is always very lose and wobbly. I put the bearing in with a kit I purchased and use a ratchet, not an impact gun. I am starting to think the hole the bearing goes into is not round anymore and distorting the bearing while I install it. Though when I put the bearing in I use very little force on the ratchet. Any ideas?
Mar 30, 2019 at 7:58 AM
Good evening,
Can you post a picture of what you see so I can see what you see?
Mar 30, 2019 at 12:29 PM
CCURRELL
Roy,
Thanks for you help.
I have now put two bearing in and get the same result both times.
Mar 30, 2019 at 1:07 PM
Got it.
The nut for that hub has a torques of 155 lbs. If you tightened it with a ratchet, then it being too loose is what caused it to fail.
Mar 30, 2019 at 10:49 PM
CCURRELL
The bearing is brand new. It was installed about ten minutes before that video. I haven't even installed the axle yet or the axle nut. I used a ratchet to install the bearing using this kit:
https://www.amazon.ca/gp/product/B01FLVOAZI/ref=ppx_yo_dt_b_asin_title_o01_s00?ie=UTF8&psc=1
I did the other side first and it worked perfectly. Is it possible that the knuckle the bearing goes into is not round any more?
Mar 30, 2019 at 11:31 PM
Yes, that is very possible.
If it did not press in like the other side, then it has been damaged.
Mar 30, 2019 at 11:34 PM
CCURRELL
Is there a way to test this? Or do I have to remove that arm and take it to a machine shop? A new arm is about $300.00 new. I will have a look at the wreckers next week as well.
Mar 31, 2019 at 1:07 AM
You would need to measure the inside diameter or the hub and the same on the bearing.
Mar 31, 2019 at 3:42 AM
