No fluid going to brakes
106,000 MILES • 1.4L • MANUAL
RYAN ANDERSON2
My rear drum brakes have no brake fluid going to them.
Apr 15, 2019 at 9:54 PM
  • 110,251 POSTS
Welcome to 2CarPros.
If there are no leaks or anything evident causing the issue, chances are the master cylinder has failed. I have to tell you that in the US, this vehicle isn't offered. As a result, my technical information is very limited. However, there really isn't much difference between designs.
You can disconnect the brake lines at the MC to see if fluid is forced from both ports. However, make sure to bleed the system if you do this.
https://www.2carpros.com/articles/how-to-replace-a-brake-master-cylinder
Apr 16, 2019 at 3:04 AM
