Rattling noise have been told bearings gone in big end can i get this repaired
Apr 30, 2013 at 5:16 PM
✓Experienced Mechanic
This can be repaired but it is not cheap, if the crank shaft has been damaged you will have to get it re ground, you may be better off getting a second hand engine or a reco off the shelf engine, check with your mechanic for prices.
