BCM location and wiring Diagram?
3.6L • AUTOMATIC
BWYCUFF
Need BMC location and wiring diagram.
Unable to print pdf.
Aug 18, 2026 at 2:27 PM
  • 55,770 POSTS
Sure, the BCM is located on the driver side up under the dash, this is what it looks like, also disconnect the battery before work begins. I would remove the driver side kick panel to help gain access. Let me know if you need anything else. Here are the BCM wiring diagrams as well.
Aug 19, 2026 at 6:46 AM
