BCM replacement
140,000 MILES • 4.2L • 4WD • AUTOMATIC
BLONDBIMBO
Bought a replacement remanufactured BCM through a reputable parts source. The original module part number has been superceded 2 times so we received module that is current module. We provided the vehicle VIN. So should this type of part come programmed and ready to install in vehicle?
Jan 8, 2021 at 1:04 PM
DANNY L
  • 5,648 POSTS
Hello, I'm Danny.
Yes, if the BCM was properly programmed it should be strictly plug-and-play. There might be a relearn procedure needed. I've attached picture steps below showing how to replace the BCM on your vehicle and have also attached the bcm relearn procedures. Hope this helps and thanks for using 2CarPros.
Jan 8, 2021 at 2:31 PM
BLONDBIMBO
This info is just what I was looking for. Thank you Danny L for your expert help. You've given me good reading to study before giving it a try tomorrow. Keep your fingers crossed.
Jan 8, 2021 at 3:52 PM
DANNY L
  • 5,648 POSTS
You're welcome!
Keep us updated for tomorrow's progress and let us know if you have any further questions on this issue. Thanks again for using 2CarPros.
Danny-
Jan 8, 2021 at 4:33 PM
