BCM replacement?
180,000 MILES • 5 CYL • 4WD • AUTOMATIC
KJONES911
Can I replace the BCM in the vehicle listed above myself? I have ordered a replacement off eBay.
Mar 20, 2023 at 4:16 AM
  • 55,721 POSTS
Yep, you sure can I assume the BCM you ordered is preprogrammed? If so, you are good to go. Here are the instructions on how to replace the BCM and its location in the images below. Please let us know if you need anything else to get the problem fixed.
Mar 20, 2023 at 10:09 AM
KJONES911
It is from a Chevy Colorado. Will that still work for my Hummer H3?
Mar 20, 2023 at 12:02 PM
  • 55,721 POSTS
If the part number is the same it will work.
Mar 21, 2023 at 5:28 AM
