BCM Replacement?
1.5L • 4WD • AUTOMATIC
ANDYSU161
  • 9 POSTS
Need to replace BCM. Don’t know how to and where is BCM
Aug 28, 2026 at 3:22 PM
ANDYSU161
  • 9 POSTS
Need a step by step guide for replacing bcm and know where is the bcm
Aug 28, 2026 at 5:58 PM (Merged)
MECHTRIX
  • 583 POSTS
To the best of my memory its it on the driver side left side kick panel and lower dash cover near the fuze panel unplu remove replace amd plug the new one in ..but to initialize it you might need a bi directional scan tool ..good luck .
Aug 28, 2026 at 6:14 PM
MECHTRIX
  • 583 POSTS
To the best of my memory its it on the driver side left side kick panel and lower dash cover near the fuze panel unplug it remove replace and plug in the new one ..but to initialize it you might need a bi directional scan tool ..good luck .
Aug 28, 2026 at 6:15 PM
