Where is the BCM located?
250,000 MILES • 3.7L • 6 CYL • 4WD • AUTOMATIC
JTUMMINELLO1
  • 6 POSTS
Everywhere i look the BCM is under the dash but in 2008 i guess the location changed. I have no idea where to look.
Apr 30, 2023 at 10:20 AM
STEVE W.
  • 15,407 POSTS
2008 doesn't have a BCM any longer. Instead, those functions are part of the TIPM (aka smart fuse box) It controls most of the body items. What is the issue you have that is making you look for the BCM?
Apr 30, 2023 at 12:12 PM
JTUMMINELLO1
  • 6 POSTS
Lights and locks do their own thing without touching anything.
Apr 30, 2023 at 1:04 PM
JTUMMINELLO1
  • 6 POSTS
I also replaced TIPM with brand new one for 600.
STEVE W.
  • 15,407 POSTS
Do their own thing how? Door locks are programmable for speed locking as well as locking in gear. So, what else do they do? Does it have any aftermarket items like remote start or theft alarm? Describe or shoot a video please.
Apr 30, 2023 at 10:53 PM
JTUMMINELLO1
  • 6 POSTS
When i stand there or I'm in my house the lights turn on and off all night long.
Apr 30, 2023 at 10:57 PM
JTUMMINELLO1
  • 6 POSTS
The locks unlock and lock on their own as well.
Apr 30, 2023 at 11:01 PM
JTUMMINELLO1
  • 6 POSTS
This has ruined 2 batteries.
Apr 30, 2023 at 11:02 PM
STEVE W.
  • 15,407 POSTS
That sounds like it has a bad intrusion module antitheft system. You will want to use a dealer level scan tool to see if the issue is a mechanical one like a bad door switch or hood switch or if it's the module itself. You can get to the module by removing the rear trim on the D pillar on the driver's side. If the unit tests bad it has to be replaced. Then the replacement is programmed to the vehicle.
May 1, 2023 at 4:02 AM
