Replaced BCM but no accessories?
160,000 MILES • 4.0L • V6 • 2WD • MANUAL
INFINITYCOM
Replaced BCM and now the headlights and windows work but no accessories, won’t crank and OBD port does not work. The old one had corrosion due to water getting in car due to clogged rain vents. I thought I was ordering the same model number but I misread the number. It fits perfectly but now these problems exist
Jan 4, 2026 at 12:00 PM
  • 55,758 POSTS
Yep, water damage is rough, you need to clean the connectors with electrical terminal cleaner and a tooth brush, then the BCM must be programed to the car, you cant just install a used BCM and have it work, I would talk to these guys, give them a call and they can help get it programmed for you.
https://www.flashmastersecm.com
Please upload a short video in your response of the problem, so I can see what's going on
Ken
Jan 5, 2026 at 2:41 AM
