Does not start after being in an accident, BCM?
92,000 MILES • 2.5L • 4 CYL • 2WD • AUTOMATIC
WISSAM1976
Dear All,
I have a problem with my car, the car doesn't start anymore due to an accident. After repairing the body, the car is still not starting. i have scanned my car, the front BCM is not shown, and the engine, transmission, signal light, headlight, and all the front parts are not functioning. i have removed all the interior and the central console for checking. Any help?
Apr 9, 2023 at 7:05 PM
  • 55,688 POSTS
Yep, that is taken apart! (Thanks for the images) I would fix all wiring and ground problems and after that let's do a CAN scan to see which systems are still not working and then fix them one at a time, also check all fuses with the systems on. You can get a CAN scanner (Controller Area Network) from Amazon.
Here is a video to show you how:
https://youtu.be/u-4syLc-ifQ
and
Here is one for about $99.00 if you need it:
https://amzn.to/3ZixY4v
Please go over these guides and report back.
Apr 10, 2023 at 7:47 AM
