BCM
200,500 MILES • 5.3L • V8 • 4WD • AUTOMATIC
KINSEYJAMES
  • 25 POSTS
My gauges (speedometer, tachometer, gas, oil, temperature and battery) and lights turned off. I found out it might be the body control module? Everything else works fine the radio, the heat/AC. Just wondering if it is a fuse or if it is actually the BCM? Tried switching with a Tahoe BCM, did the procedure and it almost worked so I switched it back. After driving for an hour it started working again.
Apr 11, 2017 at 3:51 PM
HMAC300
  • 48,601 POSTS
BCM's are VIN number specific so others will not work unless programmed to your vehicle. if it works now then okay, but if not then it has to be scanned for codes to see what is wrong with BCM or it may be a connection problem.
Apr 11, 2017 at 11:53 PM
KINSEYJAMES
  • 25 POSTS
So can I run a diagnostic test on the BCM? Or will it show up on the test? What kind of scanner would I need to use?
Apr 12, 2017 at 12:08 AM
KINSEYJAMES
  • 25 POSTS
And what kind of connection problem is it?
Apr 12, 2017 at 12:09 AM
HMAC300
  • 48,601 POSTS
the connection problem may be a bent pin or just not making a connection to BCM you need a professional scanner to scan a body module but only dealers can reprogram them.
Apr 12, 2017 at 2:39 AM
KINSEYJAMES
  • 25 POSTS
Thank you! I will get that checked soon.
Apr 12, 2017 at 2:45 AM
