Where is the BCM located?
107,500 MILES • 4.0L • 6 CYL • 2WD • AUTOMATIC
CUSFO
power windows, doors, mirror on passenger side not working.
Jun 1, 2022 at 1:21 AM
I am attaching the info on the BCM for this vehicle.
However, I would suggest testing the voltage on one of these things that is not working because it is most likely not the BCM.
This vehicle has a door module that will control each of these items so I would pick the mirror and see if you have voltage coming out of the PDM but voltage going in to the PDM from the switch.
I am attaching the info below on this for your review.
Let me know if you have questions on this.
Thanks
Jun 1, 2022 at 6:08 AM
