Can I use my VIN number to find out what BCM my van uses?
Dec 5, 2018 at 7:19 AM
DANNY L
✓Experienced Mechanic
Hello, I am Danny,
Yes, using your VIN number will guarantee the correct BCM if you need a replacement. Hope this helps and thanks for using 2CarPros.
Danny-
Dec 5, 2018 at 8:29 AM
QUICK55
MEMBER
I am sending the VIN can you tell me the BCM number I need? Thanks a lot Carl. VIN: 1b4gp44g5wb614187. I am trying to get one online. I need to change it out at one time. It is the only way I have to go. Thanks again, Carl
Dec 5, 2018 at 8:49 AM
DANNY L
Hello Carl,
The correct part number from Dodge dealer for your BCM is #R4727192AJ. Hope you can use that dealer number as a cross reference to find aftermarket or online. Dodge wants $750.00 for it. Hope this helps and thanks again for using 2CarPros.
