BCM part number needed
2,000 MILES
VLONEXOZ
Hello, I need help finding BCM number on the car listed above. The VIN is KMHGC46E89U046824.
Apr 13, 2022 at 3:54 AM
  • 110,248 POSTS
Based on the VIN, you have the V6. Is that correct? If so, the reason you are likely having trouble is that they refer to the BCM as the instrument panel module. See pic 1 below.
I suspect you are looking for part number 954003M022. However, I would like that confirmed with a dealer.
Let me know if that helps.
See pic below.
Apr 13, 2022 at 1:07 PM
VLONEXOZ
Thanks. I'm actually having trouble finding that part online. do I exactly need that part number, or can I use something close to it and they can program it?
Apr 13, 2022 at 1:26 PM
VLONEXOZ
Could I use 954003M202?
Apr 13, 2022 at 1:28 PM
  • 110,248 POSTS
I wouldn't recommend it. The parts are different internally and likely you won't be able to program it to your vehicle.
Take a look at this link:
https://www.wholesalehyundaiparts.com/p/Hyundai_2009_GENESIS/UNIT-ASSEMBLY---IPM/8621209/954003M022.html
Note: Neither 2carpros nor I have any interest in this company. I don't want you to think I'm getting a kickback. LOL
Apr 13, 2022 at 1:51 PM
